| Message |
This has been a reocurring theme for my car for about 6 months now. I've searched endlessly on multiple forums, but couldn't find what i was looking for. Problem: I start the car, rough idle. Let it warm up, drives rough, sounds rough, feels like a towing a trailer. It certainly sounds and feels like i'm not getting proper fuel. Procedures: I've checked every single electrical connection that was recommended to check while having this problem, cleaned everything. Ran ECU codes, 55 every time. OHM checked all of my connectors, all within spec. I replaced my spark plugs today, my 1 and 6 were dark/crispy, still nothing. My BCSV on my Techtom is reading ON over 140 degrees, so no safety mode. One thing i did find was that when i did the connector removal test for my injectors my 1 and 6 did not drop the RPM. If my OHM test is within spec, but my 1 and 6 drop in the RPM test, is that a definite answer that the injectors have failed? Also, what else could i test before concluding that its the injectors. Thanks a lot for your time, hope we can figure this out.
